icp tempstar blower motor question
corvairbob
michigan
i have a 4 year old tempstar icp n95esn 60k furnace and i got most of the spares for it, i'm looking for a spare blower motor. but fi nding one good used is a bit of a issue. but i'm told this furnace can use different blower motors.
blower motor Mfr Part #: 1190664 Parts Town #: ICP1190664 or the motor in it now is BOM ZWK702D006053
i now have spare switches draft inducer vacuum control bd and some others. i'm also leaning on a spare heat exchanger.
so in some research i'm told a number of motors will fit but on the havc site they will not tell me. and the mfg will not. but i'm sure there is more than one motor that can be wired into this system. now the module would be an exact part number being from what i have seen they all seem to have different pin locations for when they are plugged into the motor.
so if anyone has a cross list for this motor it sure will help. i did just get one from ebay but it had a bad comntroller and that would not let the furnace start. but as soon as i put the oem back on the furnace ran good. so i sent that back but the seller did not know if the unit was good and told me i could send it back. thanks.
i may also look for a heat exchanger as the installer told me they are not quite as good as the older exchangers were.
no issues with the system. i'm just looking for spares. being i was in machine repair i got use to having spares. and they will be cheaper now to get than to wait until i have issues and then pay top dollar for them.
i'm just looking for a cross reference chart for this motor.
blower motor Mfr Part #: 1190664 Parts Town #: ICP1190664 baldor cat# spec 35g866x530 frame 56c f586 hp= 1 1/2 volts 115/230 rpm 3450 or the oem motor ZWK702D006053 it seems the havc form will not help it you do not hava a licence. i was a electrician in mfg plants but i never had to deal with much heating systems but i did keep spares for the machines and that is why i have spares now. i can change them out but it is far cheaper to source spares then emergency needs.
so just post if you know of a cross reference chart or know what other motors will swap into this? thanks.
These ecm motors are expensive they just a few yesrs ago over $1k but have come down. United sells reman moters most if te time its te back half of the moter whixh has te problem not the windings or bearings. See if theirs a service manual on your furnace. Google your moter number a few come up.
Monday - Friday
7 AM - 5:30 PM EST
Saturday
7 AM - 3:30 PM EST
Sunday
Closed
Phone:
(813) 440-8108
Email:
customerservice@unitedhvacmotors.com
yes i have been down that road so that is why i posted it here. i did find one on ebay and got it with the understanding if it did not work i could return it. when i hooked it up the module was bad and the furnace came up with a few codes. i put the oem back in and all is well. so i sent it back. i want to have a known good spare so if and when the motor fails i will have one ready to go and i can install it. also i'm now sourcing another heat exchanger just in case that fails. the furnace is in a small space and it will be a chore to just replace it so having parts in the garage will be much easier and faster.
i was hoping that maybe some one here would have a motor cross chart. and or could tell me what other motor would work. thanks
Manufacturers don't use generic motors or their part numbers. Don't know about ecm motors but the psc motor generic if the name plate amps on the factory verses generic is .1 amp less buy the next hp up. Manufacturers play with rated amps. United isn't ebay.
i have one more question what is that little window type button on the furnace door that lets you monitor the control bd code light called? i installed a surge devise in my electric panel and had to make 2 holes in the cover, i would like to find some kind of snap in cover like i have on the furnace to fill those holes. and still see the lights so i can monitor the surge device for operation every month. thanks
