Jgrucci
The run is about 500’, and elevation 50’. I would like a min of 10gpm. What kind of pump could be best for this, and would a deep well pump work? Thanks
If you can put a submersible in the lake a 10 GPM, 1/2HP will do the job. If you cannot put a pump in the well, a jet pump will work, but it needs to be less than 25 feet in elevation from the lake level.
There are lots of ways to install a submersible in a lake. The pump can be floated just underneath the water. It can be set on a stand just off the bottom. Or it can be slid into a 4"-5" PVC pipe the same as if being used for well casing, it will just be mostly horizontal instead of vertical.
Perhaps he wants to make fish sauce?Consider a cage/screen around the end to keep out fish and plants. You might make that from hardware cloth.
