Thomas K
If I had to replace some or all of the stack, would proper pipe be Charlotte 4 in. x 10 ft. PVC Schedule 40 Foam-Core DWV Pipe?
See my post after yours, Jeff.I use abs here and its all foam core. but with pvc someone else can tell you . I would expect foam core but await as well for other opinion
Care to tell us what data went into that determination? The fact of a double top plate has little determinative value.I am pretty sure pipe wall is load-bearing, with double-stacked 2 x 4 top plates
Cheers, Wayne
Do you mean installing a 2 x 4" in a T pattern on the single 2 x 4s in the photo? I actually extended the framing of the pocket door kit I installed because a 28" door wouldn't quite fit. So there is 4-5" of stud framing extending into the closet area behind pocket door.Throw, flat stud firring onthe otherside of wall and give up an 1 1/2 of room to make it good
The only length/fall limitation is on the trap arm, which is between the trap and the sanitary tee. No limitations downstream of the sanitary tee.Using the twin street sanitary tee setup, does maximum length of drain pipe run have to be 6', or can it be 8'? I measured from exactly where pvc drain pipe enters cast iron sanitary tee in included photo to center of outermost pipe, and distance is 61 1/4"
Not really following all the framing discussion.
Cheers, Wayne
Great. I should clarify my last post by substituting "first sanitary tee" for "sanitary tee". Because obviously you are tying into a sanitary tee at the cast iron drain stack, but I wasn't referring to that sanitary tee.
Cheers, Wayne
Given that this was post #117 on the thread, you might have wanted to point back to #60 where you posted this photo: https://terrylove.com/forums/index.php?attachments/img_1776-jpg.66981/Isn't it okay to transition to the cast iron sanitary tee with a male adapter fitting?
I'm sorry, I've lost the train of discussion about the wall, are you talking about having 7" depth of wall framing? (2) 2x4s next to each other, 3-1/2" + 3-1/2"? Why would you do that?Will post more photos as work progresses. I don't think a 1" notch in each side by side 2 x 4" will damage them, but anyone reading this can correct me if I'm wrong. I don't really think it is a load-bearing wall, but could be wrong.
It would seem that you are implying that there is a threaded side port that would accept that proposed adapter.
