I need a version of this white winged part for the sink that doesn't crack
enochian
Pennsylvania
You probably want to replace that and the copper tubing with a new flex line.
Depending on what is on the other end of that pipe, you may not be able to easily just replace the nut since you'll have to remove it from wherever it is connected to, to slide the old nut off and install a new one. In that case, as said, just replacing the whole line with a flex one may be the fastest, easiest solution.
