I know this is backwards from what most people probably ask, but I have a new Gould’s J5SH shallow well jet pump that I want to run continuously (tying to control ground water level) I have the pump piped into a 20’ well in my basement with a new foot valve, the outlet side of the pump is piped directly outside to a nearby storm drain. It has 0psi on the outlet side and cuts on and off. Runs for around 1 1/2 minutes, off 2 1/2 minutes. How can I make it run continuously when I have it plugged in? Do I need to add a pressure tank or cycle stop switch maybe?
Ps- this pump is replacing an old Gould’s J5sh from 1998 that kept loosing its prime. The old one ran continuously but new one won’t. I even tried swapping the pressure valve but still cuts in and out.
Thanks in advance for any help
