I have to share: fastest way to clean a paint brush. 2 flushes.
CanOfWorms
New Jersey
I know this is yucky, but it works and is much tidier than using a sink.
I discovered it while painting in a house where the only working water was a toilet.
latex only.
Swish the brush in the bowl water getting the bulk of the paint off.
Flush holding the handle down longer than usual.
Then keep gently swirling while flushing, keep the handle down while letting the fresh water run through the brush.
When there is new water in the bowl, swirl it around to get the rest of paint out
and flush again.
Two flushes and it's clean.
Koa
Honolulu, Hawaii
I didn't think its a good idea to clean latex brushes in any drains. I think there would be some residue buildup. I would scoop some water into a ziplock freezer bag and wash the brush in that first to get rid of most of the paint. Then throw the bag away or dump it outside. Final rinse in toilet if you must. You can also tightly wrap up the brush with paint on it in a ziplock and use it the next day.
CanOfWorms
New Jersey
I have never heard not to clean a latex brush in a drain. I wouldn't dump a gallon of paint into a drain, but cleaning a brush in a sink is pretty common practice.
