joanndeker
- Messages
- 2
- Reaction score
- 0
- Points
- 0
try to explain the best i can. i have a well about 150-200 feet. i woke up this am and have no h2o. the pressure tank reads 19psi. the contacts are closed to fill tank but tank remains empty. pulled pump up out of well. when pulled it out it was not attatched to pipe. it was hanging by wires. reassembled it and turned on. it jerked and the motor ran. reput it back in well. checked check valve at pressure tank and electric to switch box and well pump. turned everything on and still no h20 filled the tank. i dont know what my cut in and cut out specs are for this tank and can not find any info for it online. i also don't know if since the pump was not attatched to pipe and all h20 ran out of pipe if it would need to be primed or something.does anyone have any info to help solve my delima? any ideas or info would be greatly appreciated. by the way my name is jodi THANK YOU IN ADVANCE!!!!!
