NoPlanB
I purchased a northern Michigan cottage that had quite a bit of freeze damage to the hot water (& domestic water) heating system . The cottage is 930 sq feet, on a somewhat creepy 18" crawl with copper supply pipes and typical slant fin registers in the 6 rooms.
I've repaired the majority of damage in the crawl space while waiting for one of the 2 boiler certified contractors in the area to come out and inspect the boiler. Finally got one of them out last week, tested it and was told it's shot. A few days later he put together a quote.
While waiting I'd had a slightly out of area plumber come out to evaluate and quote some of the plumbing issues. Turns out he also does boilers & hydronic heat. He suggested that I pretty much tear out everything and start over with pex. He told me he's seen copper systems after major freezes repaired, pressure tested to 100 psi & yet weeks later leaks will still develop. I'm anxiously waiting for his proposal.
Does this make sense? Seems like a successful pressure test of a day or two at 100 psi you'd be good to go. I'm anticipating a very scary quote! Any suggestions or recommendations are appreciated.
