NateInOK
Hello, I am trying to help a friend of mine repair his sprinkler system. There was water leaking up from the dirt, in the front yard. I thought it might have been a leak/crack in the water main to the house. After some dirt removal I found a green cap. Under the green cap was even more dirt in a 6” pvc. I pulled the dirt out until I got to, what looks like, a valve. I did some research on his system. It’s a Hunter XC controller in the garage. I can’t find the typical large green box that houses the solenoids and shit off valves. It appears he just doesn’t have one. But, the water is coming from the valve in the ground. It’s about 24” deep in the yard. My question...can this valve be repaired in ground. Digging it out, pulling the pvc housing, cutting the line, taking out the valve, then patching in a new one seems a little arduous. On the farm, we fix frost free hydrants when they leak like this one. Water comes out from the sillcock (I think that’s what it’s called) or stem, to which, the valve handle attaches. In order to close it. We just pull the parts from the hydrant and replace the stem. Can that be done with a “master valve” in a sprinkler system? Seems like it should be possible. But, I have been incorrect about a lot of things that “seemed” a certain way. Lol! Thanks in advance!
