How's this install (first plumber made a mess)
marazo
Alberta
First image is the new install. Got a new plumber to clean up and re do the lines. It looks a lot better. How did he do? I explained the situation. Got him to replace the poly-b to make it all consistent with the original brass pex fittings. Is the bend coming in and out of the softener ok? To me it seems better than using an extra elbow fitting as in the original install.
New Job:
Previos Job:
I'm not a pro but if I were doing this, I'd prefer connections that are not under stress from bending. I would have done it with elbows as per the original. That's not to say that the new method is incorrect. Like I said, not a pro.
What would bother me in the original install is the mix of black, white, and brass fittings as well as white and blue pipes. I'm a bit OCD that way. Actually, a lot OCD.
Which is supposed to be the input and output for the softener?
I don't think the plastic on the previous was polybutylene, so let's just say the fittings were plastic.
At the extreme top of the original install photo shows what appears to be a 'dead end' branch connection. Although the length of that dead ended branch is short, water trapped within will not be refreshed, which can lead to bacteria proliferation which may expand and lead to contamination though out the home's water distribution system.
As I prefer the piping to the softener to not overlap as shown in the updated install, I probably would have Tee'd off the softener's supply at a lower level, to run the supply line horizontally below the bypass valve, then elbow up to the right of the softener. Flexible Stainless steel flexible supply lines such as manufactured by Falcon, could then connect both bypass valve connections to the PEX while subjecting neither to strain, while also permitting some movement when servicing the softener, or while cleaning the surrounding floor.
As the softener is equipped with a bypass valve, this eliminated the need for using a 3-ball valve bypass in the supply piping.
I find it 'odd' for the 2nd installer, not replacing the original installer's contact card with his/her own.
First, thank you for your feedback
First installer made several mistakes, from incorrectly implementing a bypass (hence the dead end branch) to not bypassing the exterior bibs.
I did a mock-up based on your comment. Is this what you are suggesting? Are the stainless steel flexible supply lines better or more reliable than using Pex for everything? Isn't having a bypass necessary for servicing or replacing the softener in the future?
Based on feedback, I think I will re-do some of the plumbing myself.
In the second image I also posted the drain line, I know the aquatel mentions to use sharkbites as they don't reduce the inner diameter, but it seems a single elbow could suffice, and just gently bend the 1/2 pex till it reaches the elbow on the wall
1. If I read your marked-up photo correctly, you are serving the city water into the left side of the softener as you face it. Most softeners, but not all have the input on the right. CHECK IT by reading the manual for your softener. Now you may be saying that things work and think you would have noticed before. Actually, no. The effect is subtle, and few people would notice.
2. You have a bypass already hooked to the softener. That thing with the red handles is a bypass.
3. PEX connected right to the softener is fine. Flexible corrugated connectors make it a bit easier to reconnect if you ever need to move or swap out the resin. But once connected properly, PEX is good. If changing resin, you could leave the black bypass in place, and separate that. However it makes mating that back up a little more tricky. My backwashing filter has copper running to the bypass, and I was able to separate the valve body, change media, and hook back to the bypass. I would not install corrugated connectors in this installation , although if you do have input and output swapped, the corrugated connectors would have made setting things right would have been simpler.
4. In your drawing, I suspect you meant Falcon rather than flacon, but I am not sure. I tried googling flacon.
Yes, except I would run the horizontal (Red) PEX supply line farther right past the softener, then elbow up to either connect the PEX directly to the softener's bypass supply connection, or transition to flexible supply lines for the final connection to the softener bypass. Perhaps the elbow on the backside of the softener's bypass maybe rotated 180 degrees, to permit a bottom connection?
As previously stated, flexible lines will permit the softener to be moved somewhat, which is often beneficial when servicing the softener is required, or while cleaning the floor around and behind the softener. Connecting the PEX directly in the manner performed by the 2nd plumber, will place tension on the connections whereas, using flexible lines will impart minimal stress force.
The softener is equipped with a bypass valve. By turning the 2 Red arrow handles to point toward each other, will cause hard water to flow directly from the supply to the output connection, thereby bypassing the connections directly to the softener. Once bypassed, hard water will continue to be supplied to the home's fixtures, even while the bypass valve assembly is removed from the softener.
When replacing a softener at end-of-life, usual practice will be to also replace the supplied bypass valve assembly
Utilizing a 3-ball valve bypass is standard practice when a softener/water treatment device is not equipped with its own bypass valve assembly, but, a 3-valve bypass does result in 2 dead-end branches. If planning to keep the 3-valve bypass, to reduce the potential for water stagnation and bacterial contamination, suggest setting your phone calendar to remind you every few months to use the 3-valve bypass to temporarily bypass the softener so as to replace the water trapped within both sides of the connector line where the normally closed ball valve is located.
As pouring salt into the brine tank can result in fine salt particles to become airborne, or may result in splashing, suggest adding salt below a tarp or plastic sheet temporarily covering the brine tank, so as to reduce the potential for salt contact with your electrical, network and heating equipment.
One area in your photo specifies a 3/4" Tee, reducing to 1/2". If each of the lines are currently 3/4", recommend to not reduce anything.
Excellent points.
In the updated images, I've removed the bypass completely. The installers reccomended the bypass since they don't trust the ones that come with the water softener? I wasn't sure what validity to place on that statement. It does add more complexity than necessary. How many times is someone changing a water softener and if you are changing it, I'm sure you would have to do some additional plumbing anyways, so the bypass seems a bit of a moot point.
I have the exterior hose bib running straight. This new configuration eliminates some unecessary fittings.
I have two options, all pex or flex connections. I'm thinking of keeping it all pex as Reach4 suggests, partly also since the Falcon flex connectors reccomended by the water softener folks are push-to-connect that are quite expensive 55$ for two of them.
All Pex:
Inputs are correct, I didn't do a good job in the initial images to illustrate the lines. Hopefully in the updated figure, it is more clear.
That's the kitchen line which is 1/2"
I'm also not sure if I should remove the elbow, below, and run the same line manually bent to the wall. It seems superflous and ugly to have a bend like this in the middle of the air.
Also, the second plumber put pipe dope over the teflon, since the first plumbers connection was leaking. Should I leave that as is? Or clean it up and retape with teflon only.
If making changes, I would consider a cartridge filter before or after the softener.
I used to think before, but I now see advantage to after, including that the filter would catch any broken resin that came out of the softener.
However in your case, the kitchen line does not go thru the softener, so that would suggest to put the filter before the kitchen cold splits off.
But let me also say, that you already have it done in a good way now. I would not put a lot of effort into leaning toward the ideal. Surely you have other things that will benefit more from your efforts.
I would consider the
Any recommended filters or link to such I should look into ?
I’m on city water.
Maybe a 4.5x10 inch Pentek Big Blue housing. https://aquascience.net/products/ca...ouse-filtration/10-big-blue-housings-and-kits has some kits, but there are other sources.
For replacement filters, I might go with Pentek DGD 5005-10 cartriges. Replace maybe once per year.
They are lighter to pull off than 20 inch, but with city water should be very good.
Always keep a spare O-ring on hand, in case the old one will not go back. I would get a 5.3 ounce tube of Molykote-111 silicone grease, but there are smaller tubes that will probably handle for a few years rather than a few decades.
