While digging a new flower bed, I noticed that the sewer line exiting the house has corroded to such a point that there are several holes about an inch or so in size.
I've ordered 5' of black 3" ABS pipe and fernco fittings and the plan is to replace the 3" section. Not sure if I'll remove the hub on the house end or simply cut the pipe beyond the hub with enough space for flexible coupling. I'd rather not have to deal with two lead filled ends.
What is odd to me is seems the bit after the takeout transitions to 5"piper and is encased in concrete. The house was built in the mid 60's. Should I replace more pipe than the 3" section? What would you do? As far as I can tell the rest of the pipe looks ok but there is definite signs of rust elsewhere.
Bill
Bill
