hydro-newbie
Hi all, I live in a home with 2 heating zones (hot water heat), and often the area where I live is getting hotter than the temperature I have my thermostat set at (often 6 degrees warmer). I am thinking maybe my zone valve is stuck open (the one on the left).
So I just tried to do a simple test with the valves by operating them manually. I got the following results.
With boiler power on:
Left valve operates very easy and stays in manual position.
Right valve operates very hard and then spins back to auto position.
With boiler power off:
Both valves spin hard to get to the manual side and the spin back to auto.
Does this tell me anything? I did not expect the valves to move back to the auto position by themselves. Do I need to do a voltage test first before I can assume anything? Thank you.
