Todd Jamison
Hello,
I am in the process of installing Uponor Aquapex (with expansion rings) in my home.
I've been trying to eliminate as many elbows as possible by doing sweeping bends and using bend supports out of the walls.
I do have a few bends, however, that feel pretty tight, even with 1.25" holes bored into studs and joists. I made sure to keep the joist holes above 2" from the bottom of the joist as well.
My question is, how can you tell if a bend is too tight and might cause a problem eventually? I don't have any kinks in any of my bends, but I'm just a bit nervous about possible damage being done to the pipe from pressure against the bore holes on some of the bends...
Any help would be greatly appreciated!
