I have always had problems with water leaking behind the shower curtain liner. Tried a splash guard from Lowe's once and it was worthless, couldn't get it to fit properly and the adhesive was a joke. The shower curtain clips and suction cups to keep it attached to the wall also do not work. I finally ended up taping the liner to the wall and tub with duct tape.
I recently changed the curtain liner and when I pulled the tape off, of course some caulk came off with it and I had to recaulk a small section. After it dried and cured, I taped the liner to the wall and tub with masking tape as opposed to duct tape, which doesn't work nearly as well and water is getting behind the liner.
What can I do or use to stop it? I don't want to use duct tape again if I can help it. Is there a different kind of tape that is waterproof and holds well, but doesn't leave a mess and rip out the caulk when removed?
Any advice and suggestions are greatly appreciated!
