JoshinDC
I'm setting a Americast Cambridge alcove tub, and the subfloor where the apron will rest is about 1/4" lower on the drain side. I know to measure for the ledger from the high point and then to shim the floor, but what do I use to shim it? Since the weight of the tub is on the apron I assume I at least need hardwood shims, but should I push mortar under the apron around the shim? I'm not sure how careful I need to be about concentrating stress in one location on that end of the apron. If I should use mortar, would (modified or unmodified) thinset work? I'll have both on hand for tiling. If not, can you recommend a product?
Also, I was thinking of putting a bead of silicone caulk on the ledger to try and head off any creaking issues. Good or bad idea? I do not plan on placing any mortar bed under the center of the tub, per the installation instructions. I also have kerdifix, but it seems like that has a short open time and I'll be wrestling the tub into the space myself (and it's a reno so I'll have to rotate instead of slide it in.)
Thanks in advance,
Josh
Thanks in advance,
Josh
