sabiduria
can someone please confirm the following website has the right procedure. especially the following paragraphs,
To determine the cut-in value of your system, turn on a faucet in the house, watch the pressure gauge on the jet pump and note the reading when the pump starts.
The pressure in the pressure tank should be 2 psi less than the cut-in pressure for the pump. For example, if the pump cut-in pressure is 30 psi, the tank bladder pressure should be 28 psi.
https://www.hunker.com/12450051/how-to-set-the-pressure-for-a-water-bladder-tank
