How to remove stuck plastic cap over anode rod GE water heater
Gotta Fix It
California
Hi,
Need to remove a stuck cracked plastic cap covering the anode rod on a GE water heater so I can replace the rod. The plastic blocks me from using a socket and I can't pry the plastic cap off. Any suggestions to remove or cut the plastic cap out?
Thanks in advance for your help.
Dj2
California
Use a wood chisel and hammer it away carefully. If there's some foam insulation in the cavity, knock it out too.
BTW, how old is the WH?
Dj2
California
Now the WH is out of warranty.
Why do you want to change the rod?
At 14 y.o, most WHs are ready for retirement.
I would start saving money for a new WH.
Master Plumber Mark
www.weilhammerplumbing.com
you will never get that rod out after 14 years.... it will take a huge socket wrench
and an cheater bar and someone to hold the heater firmly while you attempt to
move that nut.... If you slip off the nut you will probably knock your helper out with
the cheater bar so be careful....
and like dj2 said you got to be nuts to attempt to change the rod out on a
14 year old heater
have fun
IF on the next one, you think you might want to replace the sacrificial anode sometime later, consider removing the thing before installing, use some PTFE tape on it, then reinstall. THen, you'll have a pretty good chance of getting it out later.
Artm69
Boston, MA
I have a Rheem water, basic gas 40-gallon from Home Depot, with the red, blue and white plastic caps for the hot, cold and anode rod. I've tried three different sockets (all 1-1/16) and they're all too wide to fit down the plastic cap.
The impact ones are too wide but also one regular socket I have. I swear I had it done once before wihtout issue, probably with the same regular socket.
Should I grind around the inside of the cap and force the socket or entirely remove it some other way?
John Gayewski
Iowa
Sure no reason not to. You might want a plan to reseal it after your done.
They used to sell sockets for the purpose that are both 6-point, and do not have the chamfer that helps guide the socket onto a head. I don't know if their OD is small enough for you, however.
I don't find that now. OEMTOOLS 22369 may come close, but it may have that chamfer, which is less desirable.
Widening the hole sounds worthwhile, but they really should not have forced you into that.
Master Plumber Mark
We have run into this many times... I have had to melt the plastic sleeve that goes down the hole to the anode rod with
a red hot screwdriver and then pry the whole piece out with needle nosed pliers.... THEN and only THEN you can get the socket down into the hole and it will fit onto the nut...
You got to think out of the box
Artm69
Boston, MA
So, the plastic cap is strictly for looks and serves no function, correct? Does it just sit on top and around the inner diameter of the hole? If so, then I would think it has no function.
I'll get my soldering iron on it soon...
bingow
Active Member
New Mexico, USA
So, the plastic cap is strictly for looks and serves no function, correct? Does it just sit on top and around the inner diameter of the hole? If so, then I would think it has no function...
Our previous WH was gas (State, direct vent). When I changed the anode at about the 6 year point, I left the plastic cap off, and found the pilot light would not stay lit when winds picked up. Cap back on, problem went away.
Artm69
Boston, MA
Here's some pics of a similar water heater I have. The caps are all grey and the same type.
Cap A has the anode rod, which is connected with the hot and cold nipples, as it should be.
Can caps B and C be additional anode rods, installed on the higher warranty versions? This version is only a 6-year warranty.
John Gayewski
Iowa
Stuff can happen if an insulated barrier is opened to air. It's better to try and seal it back up, but in many/most cases it should be fine to leave it off.
Fitter30
Peace valley missouri
The atmospheric vent doesn't have any screws in it. That little tab goes in to a hole top of tank. Being in calf might want to make it right.
