Kevin121
We are in the process of building a house and are starting to plan for installing a water softener. I have an outdoor water spigot that is connected to the house's PEX manifold system. The water flow will come in from the pressure tank (well source), then to a whole house sediment filter, and then have a Tee that on one branch will go to the water softener and then the PEX manifold, and the other branch would be used to tie into a PEX line output off the manifold to the water spigot.
So I am imaging two PEX lines (one from the manifold (conditioned water), and the other branched off the main (unconditioned water)) joined together with some type of valve (or other device) that will allow me to switch between the spigot getting conditioned water from the water softener, and unconditioned water that bypasses the water softener. Is there such a valve that would work for this situation? Ideally I don't want to have the ability to have both valves turned in the ON position at the same time, I would like to be able to only turn one or the other on at a time (no mixing).
I'm hoping someone can share an example of what I should be using in this scenario, or if you have a better idea of accomplishing this. Thanks in advance.
