MaxBlack
Rainwater collection system with multiple tanks and a 2" "header" that collects all the water for pumping to the house. Here in TX we have occasional days in the winter where it gets into the teens F and so I cleverly (NOT!) drilled holes at each of my tank valves so that I could let air into the header, drain the water from it, thus protecting the PVC from freezing and splitting.
These holes are plugged with Shaw plugs (Snap-Tite) which are failing and one of the holes won't take a fresh Shaw valve (slight leak) and since I'm going on a long vacation I just want to plug the doggone thing. How best to do this? Cut another PVC fitting and glue it over-the-top of the hole, maybe use a couple of hose clamps to keep it in place til the glue dries?
Notice where I'd drilled the 3/8" holes is right over some LASKO lettering which I'd have to smooth-down I guess. What do you guys think? My tanks number 8 in 2500 and 3000gal capacity some 7' tall so while the PSI is not great, nor is it insignificant (and I can't tolerate leaks, this stuff is precious!).
THANKS for any advice.
