How to fix water main supply line
John Gayewski
Iowa
I think tuttle is right about the pipe being ovaled soft copper. A sharkbite could very easily leak if the pipe is out of round and/or the o ring inside gets dinged on the way on.
Re-rounding it and solder is really the best way. Compression or pro press will also work but getting the fittings onto the pipe will be difficult if the pipe is to far out of round.
Sylvan
Still learning
New York
Thanks for the idea! I just checked on their website and I'm responsible for everthing on my property. unfortunately.
I think I posted that and someone said the water department is responsible.
Sorry to have someone give you erroneous advice.
I testified several times at depositions stating the building owner is normally responsible
"Some localities such as NYC does not require a shut-off outside the building if the main is 2" or less UNLESS requested on the original installation.
The curb valve is the property owner's responsibility in some areas. Better check before attempting to shut it"
