jzranger
Hello. Basement renovation here.
My plumber provided a drain for the vanity 16" off the ground. Cleanout directly above it. Picture attached.
I plan on adding an access panel for the cleanout, and a vanity directly in front of the main stack to connect to the vanity drain. The vanity I would like to use has an inside compartment that starts 15" from the ground, so all plumbing needs to be 15" or higher.
1. Is it legal to add 2x elbows to increase the height of the drain to 20" so that I can then attach to a P trap? Or does doing so turn it into an S trap?
2. If I add elbows to raise the height of the drain, it seems like I would block access to the cleanout... Is that a code violation?
Is there a better way to do this that doesn't involve cutting the main stack apart? What do you recommend?
Thanks
Thanks
