WellOff
The general question is how to determine when Katalox Light media is exhausted. And more specifically, If KL is failing to remove H2O2 does that mean it is exhausted?
I currently have 3 1/2 years and 177,000 gallons of water run through my setup (1.5 cu-ft). Incoming water to the backwash filter is pre-treated with H2O2 (injected into a contact tank).
Historic post-contact-tank H2O2 readings have tended to be in the 1 ppm to 2 ppm range (consistent solution mixture and feed rates). My recent reading showed 3.8 ppm. I suspect water variation, most likely less IRB (likely consistent iron- about 2 ppm, and consistent [low] manganese).
The suspected tell-tale signs I currently am experiencing are:
1) Water taste has turned "biting"/"tingling. This is similar to what I used to experience before I was using KL- it was due to [a very low amount of] manganese (why I'm running KL).
2) I'm measuring H2O2 residual out of my house faucets of somewhere in the 1 ppm to 2 ppm range when I'd never had any measurable amounts before.
3) When I recently changed my [final]l Big Blue filter (earlier than normal) it seemed to show signs of higher iron making its way to the filter and housing (water was a lot more iron-laden than I'd previously encountered).
4) I manually ran a backwash cycle and it looked only lightly cruddy, but the scheduled backwash (every two days) had run earlier in the morning.
KL is supposed to burn up H2O2 (up to far higher amounts than I'm currently seeing going in). Since I'm having a relatively high amount bleeding through am I looking at needing to replace this KL? This would be the first time I'd be changing out exhausted KL.
