MikeKenmore
i'm remodeling my basement right now. a few weeks ago i removed a shower that was in our bathroom down there. for the shower drain, there was a piece of ABS which simply slid down from the shower pan into the concrete floor where there is another piece of drain pipe that is surrounded by 4" (i think) corrugated plastic pipe.
from what i can tell there was no positive connection or a tight fitting joint. but, i didn't look very closely since i was mistakenly not thinking about the next steps. as far as i know, the previous shower worked fine enough (we hadn't used it since moving in)
now, i'm wondering what lays below my slab. from what i can tell, the plumbing is original (1979 construction) so i would like to think there's a p-trap buried below my slab. is there a good way for me to determine this?
also, is using the corrugated pipe a standard method for rough-in?
i'm very inexperienced with plumbing, so if you can elaborate in your responses, i would appreciate it.
thanks
thanks
