How to connect horizontal, vertical 90 to horizontal again
Markst
NY
Hello, I'm trying to change the current drain if possible (see pic). It will go from horizontal step down out of the joists to go against the wall under the joist make a 90 and go horizontal again.
I was thinking to use a wye fitting with a long sweep 90 (see pic). On the left it would pick up a kitchen sink drain.
On the right side it would go to a double sanitary tee and pick up another toilet then go down vertically with the clean out. Bent is up stream about 6 feet from wall. Thanks in advance
wwhitney
Berkeley, CA
Without comment on venting upstream or downstream, the configuration you show is fine for drainage. You could use a quarter bend into the branch of the wye if preferred, since the outlet of the 90 is considered "vertical".
Cheers, Wayne
