How to clean the yellow/brownish stain in sink& bathtub?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by questions1, May 17, 2019.
  1. questions1
    questions1 Member
    Oct 22, 2016
    Illinois
    will mold and mildew removing spray work to clean these stains around my faucet and bathtub? Thanks pics below
  2. DIYorBust
    DIYorBust Member
    Mar 5, 2019
    Long Island, New York
    Depends what it is, but it's not mold or mildew. I'd try something like softscrub bleach, or maybe a soapscum product.
  4. WorthFlorida
    WorthFlorida When the wife won't let you get a Harley!
    Oct 28, 2009
    Retired
    Orlando, Florida
    CLR (Calcium, Lime and Rust) Remover (I like the Bathroom Foam Cleaner),
    Scrub Free Bathroom Cleaner (Soap Scum Remover),
    and Soft Scrub
    Open the bathroom windows! If no window turn on the exhaust fan and/or a fan placed outside the bathroom to ventilate.
    If the tub is acrylic do not use a scrubbing pad at all. A cleaning brush be OK. Let the CLR soak five minutes or so, brush and rinse. May require a few soaks, rinse and any remaining then do the entire tub with Scrub Free on the stained corners and the entire tub. Spread the cleaner with a cleaning brush and let it work for a minute or two and rinse.
    For the sink, the same as above but use the Soft Scrub as a final cleaner since it will polish the chrome. Use this type of No Scratch sponge (blue) on and around the faucet.
    [​IMG]
  5. OLD TIMER
    OLD TIMER Member
    May 18, 2019
    FLORIDA
    Their hard water stains. C.L.R. REMOVER. let it soak, scrape it with a plastic knife then scrub it. don't breath the fumes and wear rubber gloves. then CLOROX CLEAN UP.
    I didn't read the post above before I wrote this, WorthFlorida is right.
  6. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    No bleach with any cleaning solution unless it is part of the cleaning solution such as soft scrub but do not mix with other cleaners. Rinse well between cleaning methods.
Similar Threads: clean yellow/brownish
Plumbing Forum, Professional & DIY Advice Extend drain clean-out to avoid foundation addition Wednesday at 9:17 AM
Plumbing Forum, Professional & DIY Advice New plan with clean outs Jan 7, 2020
Plumbing Forum, Professional & DIY Advice Can laundry box drain be used as cleanout? Jan 6, 2020
Plumbing Forum, Professional & DIY Advice Clean Cement Splatter on Water Piping Dec 29, 2019
Plumbing Forum, Professional & DIY Advice Cleanout cap doesn't seem to go back on Dec 10, 2019
