I’m looking for some diy help on changing a toilet water supply line. The line is not hooked up to a shut off valve at the source, it just goes into the wall and is shut off at a panel in the bedroom. All the videos I’ve seen online just show how to change the lines that are screwed off at the valve and replaced. Since mine has no valve to screw off of I’m assumimg I have to cut the line and attach a new connector. Just not sure the steps to take. Here’s a photo of what needs changed. The washer corroded and is leaking water.
