orion141
Hi all,
We have recently moved into a home with well water. I am interested in having an irrigation system put in to irrigate our lawn (~0.5-0.6 acre) and I believe our well (14gpm recovery) in theory should support this if the system is sized correctly. The challenge comes into play with the well set up and how to incorporate the irrigation system with the well system (the well system is rather elaborate due to high levels of iron and manganese from my understanding).
The current set up consists of a 1hp 10gpm submersible well pump (~125 deep) that runs into our home. Once the water enters the home it flows through a check valve and after the check valve there is a 40/60 pressure switch that controls the well pump as well as a chemical injector. The chemical injector is injecting a mix of chlorine and potassium bicarbonate. The water/chemical mix is then held in a 80 gallon galvanized air over water pressure tank. It then flows through an iron filter --> T20 everpure filter (~3GPM max based on manufacturer specs) --> 80 gallon pressure tank --> water softener --> domestic use.
I have had several irrigation contractors come through and there was concern about using the chemically treated water to irrigate the lawn as this contains pool shock and potassium bicarb and may damage the lawn (and is also an expensive mix) and they have suggested tapping into the well line before the chemical injector. I'm not sure if this is true, but nonetheless from a cost perspective (to avoid making chemical mix to treat irrigation water) it makes sense. However I am not sure it is truly simple to do this.
Can anyone think of a way to have the irrigation upstream of the check valve such that 1)the chemical injector is not called for when the irrigation system is called for, 2) the well pump could be called separately for irrigation (I would guess a separate pressure switch or relay?), 3) when the irrigation or domestic water is being used it doesnt overpressurize the leg of the system not in use (solenoid valve on the not in use system) as the check valves would not prevent this?
Thanks in advance.
Hand drawn diagram below.
Thanks in advance.
