Canada_DIY_Plumber
I'm redoing my bathroom to add a washer/dryer (X marks the spot). I've had to do a full gut since the sewer was under the slab and I needed to jackhammer down to it to put in a dedicated drain for the washing machine. I was tempted to just run the clothes washer into the drain currently servicing the bathtub but that's only 1.5" and part of a wet vent system. While I was at it, I moved the the bathtub drain onto the new 2" branch drain and I will dry vent it.
There is a little 4" thick wall that juts out and currently holds the plumbing for the shower valve. When I am done, that wall will also now hold the plumbing for the laundry (supply, drain, vent) and also a vent for the shower. My plan had been to just double that up with another set of 2*4s so I'd end up with a wall about 8" thick and lots of room for all the pipes.
In the latest hiccup, the 5' bathtub that came out was more like 4'11.5" and the new 5' tub is exactly 5; and it will not fit. As a result, I need to tear that wall down and rebuild it. (Sure becoming a lot of work for adding a washing machine...)
That opens up two new questions:
1) My tub is exactly 5'. How wide should I make the opening? 5'1" or 5' 1/2" and then I can use some shims when attaching to the walls? I will be tiling the surround.
2) How thick should I make the wall to hold the laundry supply/vent/drain on one side and the shower supply and vent on the other? I'm thinking I may be able to use a 2*6 instead of two 2*4s. I will be using PEX-B for my supply lines.
