K Yung
This is more for my learning purpose. I looked at an old toilet which uses a black ball as a float, As the water fill up, the ball float to a level. The rod acts as a lever and close a needle valve to shut off the water. I have a new toilet which uses a float that wraps around the water pipe. The float looks like a cup inside a cup. The float rises as the water fill up and push the level to cause the water to stop. I do not see the needle valve like the older type. All I can see is lever seems to just plug up a needle hole and the water stops. Can some one explain how this new type works and why the float looks like a cup inside a cup ?
