CountryBumkin
Active Member
I bought a Grufundos Comfort Home recirculation pump a while back (the old style with the manually set on/off timer switches). It has a built in temperature sensor and a small temp setting dial on the side.
I'm finally getting around to installing it, and I wanted some feed back.
I have a PEX manifold mounted above the water heater in the garage. I plan to run one insulated hot water line to the master bath on the other side of the house, and a return line back. The return will be tee'd into the bottom of the water heater. The hot water is only feeding the Shower. The PEX pipe only feeds the shower valve and then is tee'd (looped) to return back to garage.
I will put the recirculation pump on the return side (as shown in the drawing). The Grufundos pump has a built in check valve, but I also bought an in-line swing style brass check valve. Do I need this?
Does this setup look okay?
