How do I know if my house has closed plumbing system so I need expansion tank?
Curiousv
Tacoma WA
I found if its closed system than only I need expansion tank.
But how do I know if I have closed system?
At the main in the front where digital meter is ..I have shut off valve ( where I have to use big metal T )
what else I need to check ?
at that main where meter is ..accept meter I don't see anything else
Mount a pressure gauge. A garden hose pressure gauge can fit on a laundry tap or the water heater drain
Take a shower. Stop using all water. If the pressure rises high while the water heater is heating, you have a closed system.
Where I live, they require one. Their reasoning is that even if it isn't a closed system today, the federal guidelines call for all utilities to work towards making them a closed system to help protect the system from potential contamination.
But, need one, today, only if it's a closed system.
Curiousv
Tacoma WA
Your water department would know if you have a water meter with a check valve.
FYI - I checked it says Sensus brand iPERL series digital water meter - it shows an arrow of water flow towards the home (obviously)
