How do I get this Moen handle knob off?
YYZ
Las Vegas
Hi there,
So this Moen shower faucet is probably circa 1997. I had to cut the handle off because the set screw was frozen and stripped. I took the center screw holding the handle knob (I think that's what they call it) to the cartridge. I can't seem to get the handle knob off. Is there a trick to this? Also, do you think this is replaceable and what brand it might be?
Thanks much for the help.
YYZ
Las Vegas
Thank you sir. I've actually have two showers with the same issue. I can't seem to pull off the "handle knob" no matter how much I yank on it.
YYZ
Las Vegas
I still can't get the handle stop off. The design seems to be different than the standard handle stop. It seems like it's sort of attached to the cartridge or it's one piece? Do I need a puller or do I just use a channel lock to turn the whole thing so it comes loose? I don't want to force it.
YYZ
Las Vegas
I got it off. I had to pry off the limit stop ring and then I was able to get at the retaining clip. The handle knob is literally frozen to the cartridge.
WeekendFixit
NJ
I think I have a similar problem, I simply can't get the friggin handle off from the front.
mine looks like this. Was it hard to pry off the Temp limit stop sleeve thing?
How did you go about it?
H
You will want to have a new trim and cartridge when "wrecking" it to get the parts out.
You might try hitting it with spray oil to see if you can get things to loosen.
John Gayewski
Iowa
I would pull straight out and tap on it. When I say tap I mean best the shit out of it lol. If it doesn't want to come of nice then you gotta play hard. Moen not my favorite.
WeekendFixit
NJ
Well I have hard mineral water, and something tells me I probably have a situation similar to what pictured above when XYZ said "he got it off" . I'm still bewildered as to why I have no water coming out at all , eventhough my handle is out all the way.
