How do I get stuff out of a drum trap?
gkuhrt
Canada
Wife lost an earring down the shower drain. Somewhere under the floor is a drum trap where this has been caught (I hope). Is there any way of retrieving the earring without performing surgery on the house? :eek:
You can try using a wet vac.
Plug one of the two openings on the tub drain and use the vac on the other one.
You have a very small chance of finding it.
Most traps let stuff go right through them.
trap
If it is really a drum trap, then you remove the cover from it and then either use a wet vac, or run water in the tub to flush it out, depending on whether the trap is upright or inverted.
