I'm renovating a bathroom and I need to extend the existing 4 in. (steel or cast? I'm not sure which) waste pipe in order to attach a PVC toilet flange. The lip of the existing pipe will be about 4-6 in. short of the finished floor height.
Should I use a compression donut and reduce the pipe size from 4 in. to 3 in.? Would this result in more clogs?
Or should I use a 4 in. x 4 in. Proflex shielded coupling? It looks like a neoprene sleeve with two clamps around it. The pipe lip is slightly jagged-- it's not cut perfectly square. Would it leak if it's not square? I would have to remove wood in order to get an angle grinder on top of the pipe, so that might be an issue.
Please note the jagged end of the pipe.
It sticks out of the concrete a little under 3 in.
Any suggestions? Thank you.
