How do I attach trap to this?
Walkman
Atlanta
This is a 1 1/2" copper pipe that has a 1 1/4" chrome pipe soldered into it. The chrome piece has seen better days but is still serviceable. I'm going to install a PVC trap since it's inside a vanity but the tailpiece doesn't attach to this 1 1/4" piece of chrome.
Should I get a coupling, or should I be trying to get rid of the chrome pipe soldered into the copper?
You should be able to find a tubular compression coupling fitting that will attach to what you have. That being said, sometimes, soldering to a chromed pipe doesn't make for the greatest bond, but since there's generally little to no pressure on the connection, it probably doesn't leak.
Should I apply heat to the copper and get the chrome and solder out (or cut it flush so I could use a 1 1/4" to 1 1/2" couple to attach the trap tailpiece to the copper?
Yes,heat that joint up and remove the chromed brass tubular. Put a jersey work glove on and while its hot wipe all that solder away. If thats 1.5" copper then use a 1.5" trap. if you want to solder it in you will need a brass trap(chromed or rough)
You could buy a trap adapter and solder it onto the copper. It has a slip joint connection to transition to tubular.
Or you could use a fernco and use a tubular trap.
Tubular is sold in chromed brass,rough brass and plastic.
Goodluck!
How about cutting the copper behind the solder and and sweat a male adapter on? Then you can adapt your trap arm to it. I did this many times on an old building I used to work at when the chrome tube rotted out.
Personally I would remove the existing 1.25 tubular out of the 1.5" copper and solder in a 1.5" chromed brass trap. If it was a dump rental house that was nasty......I'd throw a fernco at it and walk out.
You may see it like a dump but it,s someones home and there your customer. If it's beneath you to work there why take the job in the first place. You must be a real sweet heart.
John
John
Sorry sir but they are not my customer. The occupy the home they rent. If they think so much of it then they should clean it up. It's ok to be poor but there is no excuse to be nasty. Love Ya!
Why try to solder a new trap into it. To do that you would have to remove the chrome plating. Cut the tubing off or unsolder the existing trap. Get a 1 1/2" x 1 1/4" MIP brass trap connector, it will solder over the 1 1/2" copper then slip the new trap into it and tighten the compression nut.
Even I as a DIYer did it this way by unsoldering the old brass tube and sweated on a trap adapter. in 1970, the builder of my housedid it cheaply by sweating the trap arm into the 1 1/2 stub. It worked fine until the trap arm crumbled away when I tried to remove the lav sink tailpiece P trap nut
