What are the spec's on the air compressor? I always thought you'd need a big compressor like what is used to run a jackhammer. Did it work without the supplemental water line?
My neighbor has a homemade airlift eductor pump that hooks up to a large tow behind compressor. I think it has a 3/4" air line and a 2" discharge.
25 gal tank, regular 110v, 5hp, 5.6 CFM at 90psi, 8.2 CFM at 40psi. The clean out you see occurring in the photos is at 85' down...and that was probably at 40-60psi air...I had just turned the compressor on and in less than a minute shot those photos. My air line was 1/4", and the compressors top pressure is 125psi...just a regular shop compressor.
It worked without the supplemental water most of the time, but when I sunk down in the sediment the air lift stopped and I heard bubbles down the well...I then thought well water wasn't getting down in the sediment or in the clean out pipe so I turned on the supplemental water and the airlift resumed...I didn't want to run the supplemental water too much because it was pulling from our holding tank and I didn't want to run out of water to the house for toilets, sinks, and showers.
When I was putting the the clean out rig away yesterday I found sediment had clogged the supplemental water line...at the end I remember turning the water line on to try and get the airlift to resume but it didn't seem like water was going down the hose when I turned on the valve...I thought I had run out of water, in the holding tank but that was not the case because I still had 45psi of water pressure at the pressure tanks...if i ran out of water the psi would be 0...I thought the air lift should still work because I was lifting it out of the sediment where there was well water, but for some reason it would not go again...that's when I stopped...because I was running out of time...I had planned to do this in one day, with overnight shock treatment, but when I got into the job...I realized I should take my time and not rush so it took two days plus overnight shock...Thats why i stopped...so i could get the well water back on...i didn't know how long the holding tank was going to last us...we used water sparingly and didn't run out.
I only accomplished a supposed 80' of clean out, unless it filled back in, even though I was able to sink the clean out to 85' as in the photos.
I think I'd like to try this again...I'm going to adjust my system to where I can pull my sub in less time and put the clean out rig back in to see if I can get down deeper...I accomplished replacing my drop pipe with sch 80 stuff so that is good and I know I got to 85' with clean out...if I can get deeper and it stays, then maybe I can just buy a 20' stick from the driller and not have to worry about cutting, taking back and threading, etc...I live 30 minutes away from the driller and have to tow my boat to carry 20' of anything...I put 20' stuff on my 16.5' aluminum bass boat...it's an old bass boat...not a pretty fiberglass boat.
Plus, I would have the benefit of gaining more well depth...besides this is kind of enjoyable to do.
