MonkeyK
I went down to my basement this evening to find a huge puddle around the boiler.
PSI on the boiler said 40, usually it is 10 or less - I drained it back down.
But the heat has been turned off for about a week now and baseboard water heat is all that we use the boiler for. The rest of our hot water comes from a standard tanked water heater.
What can cause this?
I was in the basement 2 days ago, I didn't think to check pressure then, but there was certainly no water on the floor. I asked my wife if she knew anything about it and she said she hadn't been to the basement today.
Normally when the heat is on, we need to add a little water every few weeks cause the pressure drops.
Has not been a good water heat year
- On a particularly cold day three months ago we had not topped off the boiler so it didn't kick in and we had a frozen spot in one of the pipes. Fortunately we were able to thaw the pipe and there was no apparent damage
- We also had the pressure relief valve replaced a couple of months ago when it got stuck opened after the refil valve was opened too fast.
