The existence of this guy contradicts the aboveIt really must be completely aligned and vertical.
I figured out I will need some adjustments. The shower base is very heavy (Kohler Ballast very well built!) and I was using a template to make sure the hole is where it should be and the drain should be where it should be.Not glued yet?
- you're in a better situation than I thought.
Yes I got that but I have no alternatives as the rest of the pipe is well under the slab and I did not want to break the floor to dig it out. I am all for following the code as long as the code is there to mitigate problems and not for corner cases or low risk/probability situations. There will be no inspection here and as far as I understand the 2" requirement is there becauee the pan cant hold lots of water till it drains unlike the tub. Tthe pplumbing that I am reusing was for a tub and sink...The same is now used for a shower and a sink. I count on the fact that the user will turn the tap off if by any chance the drain gets clogged or overloaded and it cant cope with the colum of water that comes to it. So I believe that this is anrasonable risk to take ....besisdes that for the first two three inches my pipe will be 2" which should make the problem milder.Hum. Seems like if not glued your all set to shift to center. Only problem I see is that a shower is required to be a 2 inch trap/drain pipe at least where I’m located. Tub is 1.5”
Notching wood framing 3/8" is no problem structurally, and not so hard to execute. And for the wall tile board to properly lap the base flange, you'll need to either notch the framing for the base or fir out all the framing.I need to move the pan toward the wall and into the framing not away of it. I have a 9mm offset . . .
