Plumbs Away
Active Member
I've recently purchased a new-to-me home, built in 1968. The fresh water lines are galvanized from the street to the house and copper in the house. When I flush a toilet or use the clothes washer, the water pressure at any other location in the house is reduced to a trickle. I know some reduction is normal, but mine is little more than a steady drip. My parents live in the same subdivision, in a house built by the same contractor three years earlier, and they also have this issue. I grew up in their house and we did not have the problem to that extent years ago. Common sense tells me that it has something to do with the age of the plumbing. I found when I replaced all my leaky supply stops with quarter-turns that galvanized nipples were used from the copper pipe in the wall to the stops and they were corroded to the point of being almost totally closed, so I replaced the nipples with PVC when I replaced the supply stops. The water PSI in my neighborhood is around 95. Any suggestions as to how I can make the pressure more stable/consistent??? Thanks!
