Patrick from IN
I had a return line and recirculating pump professionally installed almost 3 years ago so that we had (nearly) instant hot water at the far end of the house for our master bedroom. The pump has been running 24/7 since then. A few days ago I had water intrusion from a leak inside my kitchen wall on the copper pipe return a couple of feet from the water heater. It has caused thousands of $$ damage to my home. The plumber who installed the return line came out to find and fix our leak. He says that the recirculating hot water caused the leak (basically, that moving hot water "wore out" the copper pipe at the elbow), and recommends that I stop using the recirculating pump. Has anyone else experienced anything like this? I wonder if using a timer on the pump to only come on for an hour or so at peak usage times (morning, evening) would work better?
