Hot water lines hammering
Bob Labonte
New Hampshire
My hot water lines are banging when faucets are shut off. It doesn't happen with the cold water. It seems to be at or around the hot water tank. I have a system 2000 with a 40 gal tank that came with the system. Ive drained the tank. Not sure if the expansion tank has anything to do with it. I took it out and it still bangs.
Is this a new symptom, or has it always done this? Has any plumbing work been done recently? ANy other remodeling?
I did that and it is still banging
Do you get a single bang when you close a hot water faucets, whether you close fast or slow?
Heat traps on the water heater can make noises.
I was thinking heat traps on the water heater too.
Maybe change those out to see, not trapped of course.
