L. Brown667
After being gone for 2 weeks, I came home to find that my hot water is lukewarm at best
I'm pretty sure it's the lower element because
the top of the tank is warm to the touch but the bottom isn't
I hadn't run any water for at least an hour when I checked
I know there is power going to both the top and bottom elements (used one of those cheapo pen shaped doohickeys) & had just started to lean in to check the voltage with a multimeter when I heard a "pop"
I don't think I'd actually touched the probes to anything but I'm not 100% sure
I do know that that "pop" is a LOT louder when your head is right by it
Scared the bejeezus right outa me!
So...
Should I bother checking the voltage and continuity or just go ahead and replace the element?
Also, is it possible that sediment in the tank can cause the element to be inefficient?
I'm asking because the water from the tub is rust colored for maybe 1 second after not being used for a day or two
I'm going to flush it no matter what so should I just kill two birds & replace the element right then?
Or should I see if flushing it helps?
Heck, I'm pretty sure I could've flushed it and replaced the element in the time it took me to type this out!
Thanks in advance
So...
Thanks in advance
