kcroyalsfan
I built a new house 3 years ago and my wife talked me into a hot water recirculating pump. All plumbing is pex, but has copper connections. It was professionally installed. The loop is 3/4 pex and then at each hot water outlet, there is a tee and a short run of smaller line comes from the loop to feed it. The pump has a thermostat on the return end of the line, but it runs 24/7. Water is hot within 3 seconds, which is nice.
Yesterday, one of the copper elbows in the loop got a pinhole leak. When I replaced it, I noticed that it was very thin. I thought maybe the pump was causing electrolysis. But now I have researched and discovered that this is a common thing. I'm not at home now, so I don't know what size pump we have, but I'm guessing it's too big. I already don't like how much money we are spending by running the pump and hot water heater almost constantly.
This house is on a family farm, not in a subdivision, so there is no doubt I will live in it for decades. So I'm looking for a long term solution. Is a smaller pump the answer? Or should I bite the bullet and do away with the loop and pump and put in a manifold now? The quick hot water is nice, but not at the expense of leaks after only 3 years.
Also, the leak occurred at one of only two 90 degree elbows in the loop. When the plumber first put in the loop, he didn't get it anywhere close to the kitchen sink. So I asked him to extend it, and to do that, he cut the loop and put in two 90 degree elbows, and extended the loop over to the kitchen. I could easily take those two elbows out, add some more line, and make these connections straight if that would help. But again, don't want to have another issue in 5 or 10 years with the straight connections or tees.
Thanks
Thanks
