Catskill Cat
I am trying to reopen an old farmhouse. Well is 98 feet deep with a submersible pump. There is a white PVC pipe running from the well that then goes into a braided PVC hose, which then goes into a check valve and the pressure tank. The braided PVC hose sprung a leak, so I replaced. As you can see, the hose is getting sucked in/collapsed big time. No wonder it sprung a leak with flexing. The system actually works well, btw, no air in system, no cycling that I notice. What is going on here? Is the check valve on the submersible pump shot? Or is the vacuum normal but hose should never have been used in the first place? How to best fix? I was able to re-plumb the house with pex, new water heater, rebuilt toilet and faucets, etc., but am a relative novice in plumbing. Thanks in advance.
