Hi,
I'm about to cut the hole in my tile to install the closet flange in the link below. If you look on the photo of the bottom side at the black lip/ledge section right next to the steel ring. (I've also attached a photo)
Does the hole need to be big enough so this black plastic part sits within the hole and only the steel sits on top of the tile OR Does the plastic ledge sit on top of the tile as well?
Looking from the side, the black ledge, if sitting on top of the tile, will raise the SS ring about 1/16th of an inch it seems. Oatey doesn't seem to mention any suggested hole size for this or is this by design so the SS ring can swivel and be adjusted for the bolt slots
Oatey® Easy Tap® Closet Flange | Oatey
Oatey® Easy Tap® Closet Flange is available in a variety of materials and styles, with a test cap that easily and cleanly breaks out, eliminating the possibility of falling down the DWV line. Test caps hold up to 30 feet of head pressure. Oatey products have earned the trust of plumbing...
www.oatey.com
