Hey members, so after installing a PRV I noticed I'm getting huge spikes of pressure whenever a toliet flushes or washing machine runs and stops BEFORE my PRV. I probably was getting these spikes before but now I have the gauge to see them. So with my install I put gauges before and after my prv. Pressure coming from the street is around 80-90 psi. With the spikes it's can hit 170 or more but only before the valve. The pressure after is fine and does not move at 50 psi. My question is is this bad for prv valve and also what can be done to fix this.
So on the street pressure side I have my irrigation system so it is feeling these spikes too. I installed a 3/4 water hammer arrestor on a tee near the irrigation branch. Also on a hose spigot at the house I put a mini shocktrol which has reduced the spikes down to 95-100. But the mini shocktrol needs to be refilled about every other week or it loses enough air to make the water bounce when the spikes happen.
So with winter coming I want to cut in a tee on the supply line and install a ball valve with drain. This way I can isolate and remove pressure before repumping air in the trol. My question is would an air chamber be much easier to drain and reset? Or is there another idea that would be better all together.
