High pitch squealing/whistle while on Backwash
Discussion in 'Water Softener Forum, Questions and Answers' started by Topper, May 17, 2019.
  1. Topper
    Topper New Member
    Apr 10, 2019
    retired
    Girard,Pa
    Today for the first time I started up my CSI water softener and thankfully had one small leak where the water line connect to the head. Anyway I was trying to run a Backwash to Sanitize the system. Not sure how long a normal backwash last but mine was times at 10 minutes and then went on to the other three cycles. It was during the backwash when my system began to make a very loud squealing which lasted until the end of the cycle.
    Can someone please tell me if this noise is normal, or if I need to make some kind of adjustment . Any idea's would be great.
  2. WorthFlorida
    WorthFlorida Broad-Wing Hawk
    Oct 28, 2009
    Retired
    Orlando, Florida
    Is this a new unit or one sitting there installed and not used for a long time? The noise is probably water rushing through a valve? Do you know your water pressure? Are you on city water or a well?
  4. Topper
    Topper New Member
    Apr 10, 2019
    retired
    Girard,Pa
    This is a new unit which I started to install several weeks ago. I plumbed the lines but never turned it on until yesterday when I finished all the work I needed to get done. So The unit had been plugged in but on bypass. I slowly opened the water lines to the unit and purged the air from the tank, as well as purging the air from the water lines in the house. The noise was during the forced backwash which lasted 10min.
    Oh and yes I am on well water. 40-60 pressure setting.
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    10 minute backup followed by other cycles is normal. Squealing is not normal. I had an old Autotrol softener that squealed during backwash. It was very old.
    I would check with the seller.
  6. ditttohead
    Jan 9, 2012
    Ontario California
    Noise during the regen cycle is very common, it is usually velocity related. The drain line has a flow restrictor that controls flow to a specified amount. On a 10" softener tank anywhere from 2-3 GPM is normal during the backwash and brine and rinse cycles. Small or restrictive drain lines are also a common cause. I highly recommend no less than 1/2" PVC pipe or 5/8" soft pvc tube for a 10" tank to help lessen drain line noise.
Similar Threads: High pitch
Water Softener Forum, Questions and Answers Microbial count high at Softener Apr 14, 2019
Water Softener Forum, Questions and Answers Is .35 ppm chlorine level high enough to rate filtering pre-water softener? Jan 29, 2019
Water Softener Forum, Questions and Answers High Flow Softener? Jan 10, 2018
Water Softener Forum, Questions and Answers Up for a challenge? Low pH, high iron, + Mn, discharge to septic... Sep 15, 2017
Water Softener Forum, Questions and Answers HighTDS Aug 30, 2017
