Pmaru77
I had a leak a few years back, it was soaking the kitchen hallway ceiling, and there was a lot of plumbing above,
including 2 back to back bathrooms. The drywall was soaked pretty bad, so I punched a hole in it assuming that I would have to replace it anyways. Water was dripping down fairly steadily and was like clockwork, but faster than tick tock. I called a plumber and he nailed it right off the bat. It was a toilet wax ring that was passing water, and not only that, the water valve that feeds the toilet reservoir was not shutting off all the way, as it was slowly feeding water into the toilet. If you put your ear to the valve (with the toilet cover off) you could barely hear water running. So the combination of a leaky valve and a bad wax ring seal caused big wet spot on the drywall ceiling. To this day, I'm kind of pissed that I punched the drywall out to see what was going on. As the problem was not there, but in the upstairs toilet. The fix was to just install a new toilet. Turns out that the toilet flange was crap, and the job ended up remodeling the whole bathroom (it needed it). If I had called a plumber first instead of ripping a hole in the drywall, you think he would have figured it out without popping a hole in the drywall? In my wildest dreams, I would have never thought that a leaking valve and a bad wax seal would happen at the same time. So much for my knowledge.
