I have a shallow well that is used only for the sprinkler system. I had somebody install a pump, pressure tank and lines about 2 years ago. Just a few days ago the pump stopped working (Sta Rite Pentair 1 hp). I decided to change the pump myself and that is where all of the troubles began.
First of all I confess my total ignorance but I wanted to try and learn.
This time I decided to install a check valve on the line that comes out of the well. The new pump is a 1 1/2 hp generic pump from Home Depot that does not have a pressure switch, so I did install a new one 30-50 PSI on the line between the pump and the pressure tank (bladder tank) along with a pressure gauge.
This set up is connected to a control box for the sprinkler. I made sure the switch is wired correctly and I do not see any lines leaking. These are the issues that I am facing:
As soon as I plug the pump it will start running, pressure gauge goes up slowly to 40 PSI and zone 1 of my sprinklers will go off even if control box is not connected. I can not stop it.
The second problem that I have is that as soon as I unplug the pump, pressure gauge shows a rapid loss of pressure back to zero.
Please help me solve this
