I not sure what's going on and I need some help. I have a well, and the pressures all seem normal. The pressure reading on the gauge looks normal (30/50 pressure switch) and the pump cuts off at just over 50 psi. The problem is that there is some sort of relief valve upstream of the pressure switch, and water is coming out of the valve in a jet.
All the videos I've looked at online don't show this valve, they only show a traditional pressure relief valve. My normal pressure relief valve is not leaking. The water is only coming out of this upstream relief valve when the pump cuts off. I have a feeling that this upstream valve is bad, but I'm not sure.
If anyone has any ideas about this upstream relief valve, or if it's bad, I would love any ideas/advice.
Thanks.
Thanks.
